? on procedure to change jets/needle position...
Knowing I may be doing this soon, can anyone explain the easiest way to change the pilot/main jets and needle clip positions, etc. on an 07 CRF 250....
I am looking for what really needs to come apart, etc. and curious if there are any tricks....
:applause:
For the just just loosen the carb boot clamps and rotate it. Remove the float bowl plug and youre good to go with the Main and Pilot jets. As far as the needle goes I believe if you remove the gas tank you can get at the top of the carb from there... hope that helps. I'm sure someone can explain it a lil better.
