power bomb to yoshi slip on?
hi guys need to know if a fmf power bomb will bolt up to a yoshi rs3 slip on? without any modifications or things needing to be made up etc etc.
cheers in advance:ride:
If the slip on is for an E, yes.
The FMF is 41 mm O/D.
If the slip on is designed for an S and uses the S gasket, no, or yes if you make a gasket.
Neil. :applause: :applause: :lol:
is it an easy job to make a gasket mate?.....
Depends on how much slack you have to take up :applause:
I used thin alloy sheet (a camping stove wind break) to start with, and a layer of "Hylomar Blue" as a sealer.
Worked Ok, but after a couple of thousand miles it started to blow, so I turned one from alloy tube.
It is a very simple job, if you have a lathe, or know somebody who has the use of one.
If you have to pay a local engineer to make one, I suppose about £20.00
Neil. :applause::lol::cry:
