klx 110 jetting
what is a good jet combo to boost out put on a stock 2005 110?? also would it be the same if i added a pipe???
any help is appreciated/////////////////
spocket
In stock form the 110 really would not benifit from jetting. If you were to to the exhaust mod and air box mod then you could go to an 85 main and 40 pilot. It should run good with aftermarket exhaust and an clamp on air filter and still use the same jets.
right you are king110, unless you have a pipe or airfilter, or both the 40, 85 jetting would not make the bike any better in fact it would be worse.
