2003 KLX 125 jetting question
my 12 yo daughter rides a KLX 125 2003 and has just started experiencing trouble kickstarting and the engine bogs at low rpm's. additionally, the engine seems to prefer to run with the choke on. What should I do to correct this?
My son rides the drz125, same thing. Pull your carb off and clean it especially if it sits for long periods of time. I now make my kids turn the gas off and run the bowl dry. The green people keep messing with the fuel and now it seems to gum up carbs quick. While your carb is off rejet it, my sons is running a 110 and I plan on upping it before summer, stock these things are way lean. By the way, its hard to find a kit for the klx/drz the ttr125 uses the same carb.
