1982 XR80 Forks
:applause: I have a 1982 XR80 and was wondering if the front forks can be adjusted to make them stiffer. I just replaced the fork seals and filled them with atf to the manufactures specs. Will adding more fluid make them stiffer?
adding oil will help with bottoming, I added a few washers under the fork cap on each leg to help the bike ride up higher. Seems to have helped good.
