07 525 exc tail lights
i just picked up a 07 525 exc
the tail lights will not stay in place is there a trick to themor im doing wrong.
do i just have to push them in harder to get them to stay in place .
Do you mean the turnsignals for the brake light? If it is the turnsignals you need to remove the lens, pull out the chrome reflector, slide the plastic turnsignal body onto the stalk, reinstall the reflector in the groove in the stalk and reinstall the lens. Be careful when removing/reinstalling the lens as it has a small tab that breaks off rather easily.
Mine came undone on the other end away from the lens, I just took em off anyway. Run a 06 rear under fender looks sexy....
i have the 06 rear under fender coming should be here tommarow.
but i have to have turnsignals to be street legal, here in michigan.
