F250 with 6.75' bed and 5 wheel
I have a f250 crew cab short bed 6.75 ft. I want to pull a WW SL fifth wheel.
The pin appears to be forward enough that I could pull without problems. Does any one have this set up without a sliding hitch?
I just had a Reese 16k sliding 5th wheel hitch and air bags installed in my 06 F250 diesel short bed. I have not needed to use the slider but I like the insurance of having it in tight situations. Some of the newer 5th wheel trailers have rounded or tapered front ends to give more clearence. It is kind of like 4WD. You do not need it in most trips but boy are you glad you have it when you do need it. I think the slider was only a few hundred dollars more (I bought my hitch used).
