YZ250 - Help Please, Front Suspension
Would someone please let me know if the front forks from a 2003 YZ250 are a direct swap with a 1999 YZ250? Can the forks be just be swapped into the existing triple Clamp? How about the whole Triple Clamp set up with forks? Thank you in advance for your Help! Oh Yea... take it easy on a noob please...
Actually i'm hoping to bolt the 03 forks to the 99... It seems common sense that it will work both ways.... thanks for the help, does the same hold true for triple clamps?
upper clamps are the same, lower clamps i'm not 100% sure (but 98%) :applause: are the same as well
I missed out on the set of 03 forks. :applause: Can someone tell me if a Set of '04 Forks will slide into my '99 Triple Clamps? Will a complete '04 Triple clamp and Fork unit bolt up to my '99? Are all the mounting points for the front brake and guards the same? Thanks in advance! :eek:
