Weight of the stock exhaust system
From my '04 CRF250X:
Header weighs 1 lb 13 oz
Muffler weighs 7 lb 01 oz
Total weight.. 8 lb 14 oz
You could probably get away with saying it weighs 9 lb :cry:
Header includes heat shield and bolts but not header mounting nuts.
Muffler includes heat shield and bolts, muffler band and bolt, joint gasket, exhaust diffuser and spark arrester, but not hanger bolts.
The exhaust diffuser is drilled with the 11/16" hole as per my web site, so that could add in another ounce to get the stock weight. :applause:
Oh, I also took off the little rubber standoffs for the side number plate :applause:
BTW, the muffler must be stainless steel; it's not magnetic.
The header is magnetic... could be titanium, but I doubt it. :lol:
Does anyone know how much the stock 250x exhaust sytems weighs?
Not as much as I expected. I took the can off today and tossed it arround a bit to get the feel for the weight, and then I bolted it back on.
I was expecting some serious weight issues and was contemplating using an R can in its place, but it didnt feel too bad.
Since you put the 7 lb stock muffler back on----just FYI, a FMF Ti Powercore weighs in almost 3 lbs less :applause:
