rekluse z V/S pro
first, how can you tell if you have a gen 3 rekluse or not. i bought one with perch adjuster with only a couple hours on it.
how about some pros and cons of the Z and the PRO from you guys that have experience with both. im just wondering if i should resell mine and go right to the pro. thanks guys, scott
Here's the link to www.Rekluse.com that compares the two. It's pretty much on the money.
http://www.rekluse.com/z-Start_tables.htm
The biggest difference between the two is clutch lever feel/manual control. As it says, if you use the clutch lever at all, the Pro is for you. Above 3000 rpm, you notice nothing different than stock. You can abuse the lever and it responds as the stock clutch does. Let the RPM drop below 3000 and you have your choice to let the Rekluse Z-Start Pro do the modulation (function of RPM) or you can still use the lever if you prefer.............
It slips it better than you can and completely dissengages if the RMP reaches that of idle, everytime, all the time. Hope this helps
