how do you remove rear spring?
I have an 05 crf250r. I bought a heavier fc rear spring and I cannot figure out how to get the spring off the shock. I couldnt find any schematics on how the shock is together.
loosen the top rings so the spring floats between the top and bottom..then use a rubber mallet and tap the bottom ring on the bottom of the shock there is a clip inside holding the ring on.. pull the clip off and the bottom ring comes off with the spring..
hope this helps
jeremy
thanks for the help and the link. I didnt realize that bottom plate came apart.
