Fly Wheel Torque???
the torque for the flywheel is 47 ft lbs. w/ the bike in gear the rear brake on and a bar going through the rear sprocket and jamming against the swing arm I could only get it torqued to between 40 and 47 ft lbs, somewhere in between the clutch slipped. The nut isn't comming un done, the direction the motor runs is in the opposite of which the nut loosens... If you want it to be easier you will need a flywheel holder of some sort.
