Replacing the lock-washer on the front sprocket?
So I took my front sprocket off for the first time. I noticed that the manual recommends replacing the locking-washer around the nut every time you remove the front sprocket. They are about $5 a pop. So my question is:
Who replaces the lock washer everytime, and who re-uses it?
If you re-bend it back on, how many times have you done that before replacing it?
Any horror-stories?
Thanks!
i dont take my front sprocket off very often so i replace it every time i take it off.
I just pulled my motor out and as I bent the tab out and started to fit a socket over the sprocket nut it just came off with my fingers:eek:
I for one will be using a new lock washer
Thanks guys. Great, doesn't sound like any horry stories, although, maybe an "almost". I will reuse, but purchase a spare, just in case it starts to look like it needs it.
I re-used mine. only one of the tabs was bent down on mine, so i just made it so i bent the other one down this time. simple
I get about 5 reuses out of mine. you can tell when its getting ready to crack, and I keep an extra in my box
