to rekluse or not to rekluse?
I found it very helpful with the tall first gear. Was able to gear up to 47t rear even for the tight stuff.
Took a while to get it dialed but now it is great. Have had it for 20hrs and haven't had to adjust the plates so the wear isn't too bad. The perch adjuster is sadly a $100 must have.
some moto mostly harescrambles and woods i heard through the grape vine rekluse is coming out with a new clutch that will slip and work like a real clutch along with being auto.......the only thing that i am apprehensive about on the rekluse is the on or off feature on the clutch pull i can't slip it out of corners or in technical stuff
Is the rekluse better than a Hinson slipper clutch?
I do mostly track riding, so I'm trying to find the best setup :applause:
Rekluse for HS or GNCC is priceless. I would highly recommend it. Probably not for full time motocross. A Slipper clutch is totaly different.
