Ct-90
Hi, I know I should be in vintage, but knowone seems to know. Does anyone know how I would remove a timing chain off my 72 Honda CT-90? There does not appear to be a master link. Thanks for putting up with me.
There isn't a master link in the timing chain.
Remove the side cover on the cam chain side. The chain should be around the crank. It should slide down and out and around. You'll see once you get the cover off. You may need a puller to get the flywheel off. Once that is off the cam chain will come off for sure.
"O"
