Sunstar Steel Z Sprocket: Offset teeth.
Hello. I was just thinking about buying a Steel Z Rear Sprocket from Sunstar. It says the teeth are offset. I normally run a 52T rear Sprocket on an 06 CRF250R, but with the offset teeth do I need to run a different number of teeth than normal? Also, how much heavier are they than the aluminum ones? Thanks.
Bradley #721
Ok, thanks. Well, I bought a Regina chain, but I need Sunstar for the sprocket because I am sponsored by them. I already talked to the sales rep though. It's worked out now. Thanks for the help. I would recommend Sunstar for their customer service alone! Their sprockets are awesome too.
