Vortex X10
Hi Can anyone help me out with the settings on the Vortex ignition. I have it set on 2 and have lost the sheet that came with the ignition. Anyone got a copy to tell me what the other settings are? Thanks
Can anyone post the settings on the forum? Thanks
I would like to see those too!
There is a search feature you know. I posted this a while back..
theDogger's Avatar
theDogger will become famous soon enough
Add to theDogger's Reputation Report Post
Talking Re: Vortex question
OK here ya go...
This is from the X10 Map File:cr4fx6t1.saf
Map 1 Best Over all Power............................................. .............11,700 RPM
Map 2 Traction - Flat Torque............................................ ..........11,700 RPM
Map 3 Traction - Torque............................................ ................11,700 RPM
Map 4 Traction - Linear Power............................................. ........11,700 RPM
Map 5 Traction - Linear Power............................................. .........11,700 RPM
Map 6 Power Map - Mid-Range............................................. ........11,700 RPM
Map 7 Power Map #2................................................ ..................11,700 RPM
Map 8 Power Map - 2002 Best.............................................. ........11,700 RPM
Map 9 Power Map 2003 HRA - High Comp........................................11,700 RPM
Map 10 Standard Map w/ Raised Rev Limit........................................11,70 0 RPM
Standard Rev Limit 11,100 RPM
Main Jet Tested 162
Hope that this helps...with no bar switch it defaults to Map #1
For MX most guys are running Map #3 off the start then switching to Map#1
I also believe that there is a earlier software version that is the exact opposite of what I posted.
theDogger
Thank you! How would you describe "linear" power?
I was also thinking of using some traction mode like #3, because standard mode (#1) has all ready so much torque that actual torque mode would be uncontrollable. Or what to you think?
linear on a graph means a straight line relationship. So on an motorbike power curve, it would be a smooth manageable acceleration I think.
