help regarding FS o ring
guys please help
i just installed my kouba link fuel screw. i didnt see any o ring on my fuel screw when i removed the stock fuel screw. it only have the spring and washer , no oring. crf250x 2006
thanks
The oring probably was still in the Carb. They will stick in the opening when you remove the fuel screw. I always fish mine out and place it on the new fuel screw, this way I know it is not missing
I lost minhe and had to go buy a new stock screw to get the O ring found the washer on the garage floor after I bought new screw.
Its probably still in the carb.
A few of us teamed up and bought some extras just in case - the fuel screw needs to come out to change the leak jet and occasionally to clean the carb.
Those things are really easy to loose.
Ordered from Sudco:
Keihin part nimber.............."description".............pric e
KE 021.041.......................1290-812 spring.......$2.31 ea
KE 021.042.......................16075-KG8 O-Ring.....$0.63 ea
KE 021.045........................0301-803 washer......$0.53 ea
Why don't dealers carry those things?
