How far to press swingarm bearings in????
I didnt pay attention when i took them out. I was wonding if they sit flush with the inside seal or if they are flush with the out side and then there is a gap between the seal and bearing. Thanks
11-11.5 mm from the outer edge
You need to leave room for the thrust needle bearings, washers and seals.
if I recall, there is a step in the bore from the outsite for the thrust washer to rest against. The bearing needs to be just past that so it doesn't interfere
