How much fork oil.
Alright so the manual that came with my SSR-110A1 is pretty much useless. Anyway I was wondering if anyone new the correct amount of oil to go with in each forks. I'm planning on running 15w which I figure should be good enough since i only weigh 150lbs. Also I've never changed the oil in forks before but I believe I just undo the aleen key at the bottom to drain it and refill is from the top of the fork.
You might have to try some different amounts but somewhere in the 90-110cc range should get you close then you can fine tune from there.
if you wiegh 150 you won't need more than 95cc of oil. I weigh 185 and I run 95cc of 20wt and they are a little slow on the rebound
