2 questions
I'm looking to swap out my 7/8 bars for the fat veriety. I can get new rubber mount top clamps or whole new top clamp without the rubber mount.Will I notice a big differance going from rubber to non rubber.?
When going to aftermarket reeds do I need to run their cage also ?
Thanks
Doesn't the reeds come with the whole kit anyways?
If you buy an aftermarket reed cage, yes it will come with the reeds for it. I thought the guy was asking if you had to buy the reed cage to use any aftermarket reeds in which case the answer is no. I do know Boyesen sells reeds that will bolt into the stock reed cage so you don't have to buy Honda's reeds if you don't want to. There may be other manufacturers who sell direct replacements as well.
Yeah, Boyesen offers direct replacement reeds for the stock reed cage in both the fiberglass/epoxy and carbon fiber varieties.
If you go with the solid bar mounts and do notice added vibration, you can fill your bars with expandable foam from the Home Depot or any other hardware store and that will kill most if not all of the vibration transfer...
