head pipe help
i am trying to put the 2004/5 racing 250 4t head pipe on my 2002 racing 250 4t but it is impossible to slide him in.
what is the right way to do it and is it possible.
thr 2004/5 has only one pipe and mine is 2 with a middle
section.
please help.
The head pipe might not be spaced correct between the 2 ports. Check that. I hade to put mine in a vice to get it to work. Everything else should work.:applause:
Go to the parts manuals and check the part number but if my memory is correct the exhaust manifold is differrent
Anything is possible, it just depends on how much modification you are prepared to do. I am guessing tho you are looking for a straight forward swap over and in that case it isn't going to happen as up to 03 models it was a twin head pipe with 04 onwards being a single head pipe. My advice is find a pipe that is compatible IE something for an 02/03 model :applause:
