Drz Engine vibrating at high revs
My engine noise it getting loud now...Took my bike on a track day and couldnt help noitce the high pitch metal hitting metal vibrating noise at high revs....Is there a cure for this??? oh I have a 2006 DRZ400SM
I am sure there is a cure, but your desription is not poosible to diagnose.
Do you have a MCCT or ACCT?
Did you recently check valve clearences?
Is you bike full of oil?
Did you check for loose fasteners?
is your bike stock?check your engine mounts.the drz willl vibrate at hi rpm
How full is full? and its vibrating inside the engine....I have a ACCT. the MCCT did not make any differents when i fitted it. I took it off for warranty reasons
Under warranty? Take it to the dealer, at the least. Have them create a repair order of your complaint, esp. if they claim "it is normal" and it turns out not to be.
