6.6 gallon tank
I don't know the dimensions on the "bigger" radiators, but most likely they are the same height and width, with a thicker core. If that is the case, it shouldn't be a problem, but you will be limited as to which rad guards will work. If the new rads are wider, there is no way they will clear adequately.
The Bulletproof Designs guards should be fine with higher capacity radiators, assuming same HxW dimensions, and they are an excellent choice for this tank with the stock radiators.
John Davies
Spokane WA
