XR250 Valve adj question
That's what I realized after I did it. But now the bike is sounding a bit strange. I was wondering if done incorrectly...like I did...if there was any chance the valve could hit the piston. I would think not, since we're only talking a few thousands clearance.
Thanks
BTW, the strange sounding/running of this bike was one reason I adj the valves. There was a "cutting" out problem to begin with so I was going thru the bike to eliminate things. Checked carbs, valve adj, etc.
Hey, I have the same problem, but I am not sure about the sound, because I have a loud metal sound coming from the valve system. I already adjust the valves, but I still have that noise. When the valve is too loose the sound is loud?
The more loose the valve clearance is the louder it gets. A loose valve clearance is better than a tight valve clearance, but obviously, an in spec valve clearance is the goal. Valves that are run too tight eventually burn and/or "suck" (break off).
