Mods for a RT 100
Well my little brother has a 1999 Yamaha RT 100 and i've rode it before an personally i hate the bike but he seems to love it so i was wonderin are there any mods out there for this typer of tryin to help this poor bike out
What mods are you looking for? I would maintain the bike properly as the number 1 mod.
If your brother loves it, leave it alone. A more powerful engine would over-run the suspension. Better suspension would then require better brakes...and so on.
It probably better to have fun with this bike and save for a yz 85 if you want to get crazy!
the 100 will last forever if maintained properly
Your bro loves it and it is not yours. Let him decide!!!
It is a beginer bike so if you want more out of it sell it and get something else
heres me a long time ago on my rt100 jumping it lol , what a bike!
there is not much in the way of mods for the rt100. here are some things i did to mine: remove the snorkel on the air box, change the gearing (after market sprokets), and i noticed a small difference when runing it with the high octane fuel. but if you are going to remove the snorkel, you might not want to do much wet riding, the carb will suck in a lot of water and the bike will run like crap. removing the baffle will help a little bit but it is not worth it cause it sounds just plane bad. good luck, but i do sugest just bying an 85, lots more power, and manny manny mods. happy riding
  • Similar Content
    • By Rixter
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
