DR650 heavy duty tubes?
where do you guys buy your tubes at? I just bought some new Dunlop 606's and bought some Moose Heavy Duty Tubes, but just realized my front tube is bigger then my rear..
My Front tube says 3.00/3.25-21 , thats too big isn't it? It appeared to be the only one moose made in 21 inch wheel..
Also the rear says 2.50/2.75-17 , is that within the range of the rear wheel? looks little small maybe? also appeared to be the only one Moose made in 17 inch wheel
You have the right size for the front..not sure on the rear.
I run an 18" MSR Utra Heavy Duty, fits fine
$15.95 at Rocky Mountain MC
any confirm that this would work?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280087452157
IRC Heavy Duty Tube: 4.00/5.10-17 (TR-4 stem)
dunno what the TR-4 stem means, is the 4.00-5.10 enuff range for a 130/90/17 rear tire?
also any confirm the 3.00/3.25-21 moose tube I already bought will work? for 90/90/21 tire? or is it borderline for being almost too big?
The 4.00/5.10-17 TR-4 will work for the rear. The 2.50/2.75-17 WILL NOT WORK FOR THE REAR. The Dennis Kirk website, www.denniskirk.com, has a good description of valve types and size comparisons. You should be good to go with the front tube you have. Use lots of baby powder on both.
