Who makes body parts for a 95'
I got a good friend who is looking for some aftermarket plastic for his 95' Husky 2S i believe is what its called, its a 250 two-stroke. Any help would be appreciated.
If its a WR our CR you can just change the tank and seat to what moddel you want, for eksampel the 2007 tank, seat and plastic..
I just converted my Wr250 2000 model in to a 07, and i cant say that I see any driffrens on the frame from 95..
So you dident have to do any brackets? I'm thinking of doing a convertion of my 01 Wr 125 to the 07 plastics. Did it fit bolt on on yours?
If you want to do it 100% you must weld a nut on the backbone on the frame, but there are many ways to do it if you dont want to weld. But I am going to weld an nut on the back bone..
the Nut I am taking about is rigth back NR 31 on the pic on the pic to the right..
Ser også du er fra sverige, så da er det vell kansje letter å forstå norsk en engelsk, hvertfall letter å forklare på norsk..
Når jeg monterte min på måtte jeg ta av de støtt demperene under tanken, pga dem var noen mm for brede. Men det var bare 2 min med vinkel sliperen så var den så gled det rett på..
Eller så må du sveise fast en mutter på ramma. men det er mangen andre måte du også kan løse dette om du ikke vil sveise på ramma. Feks Patent bånd.
