pivot works or OEM parts
I got a pivot works fork seal kit and some OEM fork parts (o-rings mostly) because I thought the kit only had the bushings and seals. Turns out the kit has every damn o-ring already in it. So should I use the OEM or pivot works components? The OEM washers look to be of better manufacturing quality but looks can be decieving.
the pivot works things are rebuild to oem specs
