Cam noise . . . engine problems (cont)
Recap: installed TT fly wheel and set the valves to the middle range of the stock specs. As I have the RHC cams Eddie suggested I tighten the clearances and the cams quieted down a bit. Take it out for a shake down ride, get about a mile from my house and life turns bad. Cruising in 4th gear and all of a sudden there is a CLUNK from the engine and the engine dies. Get my buddy to rescue me in my pickup and the bike is now in my garage.
Got around to opening up the engine this morning and my problems appear to be as follows. The right exhaust bucket appears to be much lower in the head than the other three valves. When I rotate the engine manually there is a grinding noise (which appears to be more from the bottom end) and I eventually get to a point where the engine does not want to turn any further. Have I dropped a valve?
I assume at this point I am going to have to take off the head and determine what's what. Is there some logic to disassembling the engine when it is not at TDC? Right now the cams are both pointing up and are not in contact with the valves so removing the cams shouldn't be too hard. Do I index every thing as usual and just make sure to reinstall the cams as they are?
I assume that if I have to take off the cylinder it won't really matter where every thing is as there will be enough stuff broken that I will have to start from the bottom end and line every thing up.
Let me know what the best way is to proceed from here. Thanks for the help in advance!
have you ever done the primary nut fix?
you need to put it TDC so you can see if the cam timing is off now.
Yup, sounds like a bent valve. Pull the head, inspect the piston. It probably is a good idea to pull the barrel too and check for any con rod and crank play. Becnt valve is bad, grinding from the lower end could be a real pain.
When reinstalling the cams, you want to follow the manual, having the lobes pointing away, marks lined up yadya yada.
When tearing a engine down, it does not have to be at tdc or any place in particular as you are going to line the stuff up upon reassembly.
Haven't done the primary nut yet. I think now would be a good time to do that :applause: How should I go about tightening it if I have the TT flywheel that does not have the 26mm slots to hold the crankshaft?
I will strip off the right side cover now, but I'm assuming that I want to do the primary nut before removing the head.
At this point, the best thing would be to loosen the primary nut (if it is not already loose). Pull the head, pull the barrel, check for bottom end damage. You can apply the primary nut fix as you button things back up.
OK, that's what I was thinking as well. The primary nut does not appear to be loose. Taking the head and cylinder off is not a problem for me, but is the best strategy to loosen and tighten the primary nut without having the hex head portion on the TT flywheel? I've got rubber strap things that act like an oil filter wrench, but the rubber stretches too much if you put any real pressure on them. Any other suggestions for attacking the primary nut?
Well... Others may yell at me but... you can do the old "Rag In The Gears" trick. Simply get a heavish piece of cloth, put your socket on the nut, stuff the rag in the gears as you turn the nut. The rag will jam them up and enable you to loosen the nut. This is how we did in olden times.
A better way would be to simply use an impact air gun on it.
if the primary nut wasnt loose,you didnt have have the cam timing right.
is this problem sorted yet?
You can also use a strap wrench on the flywheel, which is also the best way to tighten the flywheel nut, with this flywheel.
Neil. :applause::lol: :lol:
Hiya Neil,
He tried that with the one he has, but it was too 'stretchy'. He'll certainly need a good one to reassemble the P Nut properly, but I think he may have bigger problems now.
As Eddie suspects, the valve timing might be off. See if you can determine if it is. I understand this might be tough given the fact you cannot rotate the engin through complete revolutions. It is important to determine this as it might identify why you are having ther problem. This is nearly as important as resolving it.
Right, when I took out the spark plug the tip was totally crushed from some part of the engine hitting it. I double checked the timing when I put the bike back together, but then again it still could have been off. My strategy is to take off head, remove bent valve, check for damage to head and cylinder, remove cylinder, check for bottom end and start lining every thing up from there.
At this point I'm not really sure what went wrong, but I assume I will have a better idea in a day or two when I have the engine completely apart.
Thanks for the help and I will keep every one updated.
Crushed plug is probably the bottom end bearing from the rod, assuming it is the correct pug. Would also explain the grinding sound.
A strap wrench with a steel band is the type you need, often sold for oil filters.
Hopefully not, a valve bent or broken, will do that when the piston hits it :lol:
I found this the hard way in the mid 70's on Honda CB250 K series twins.
I had a collection of pistons, heads barrels and cranks that would have given a race team a headache.
I gave up on them after the 10th big bang in a year.
Neil. :applause::lol::eek:
Right now I think it might just be as effective for me to send the engine to Eddie and sell off my FCR and RS3 pipe as ebay prices for these look to be pretty strong right now. The freewheelers crank, FCR41 and a bigger pipe would be a nice addition :applause:
That's only a thought for now, I'm still going try to figure out what went wrong with the engine when I have time. Life is too freak'n busy, I just want to ride the bike!
  • Similar Content
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By drzvfr
      I did the fix last night and took some pics and notes to make this easy on people that haven't done it and want more detail. Please chime in if you think I've missed something.
      Required Tools:
      Set of Allen wrenches
      #3 Phillips screwdriver
      small flat head screwdriver
      8 & 10 mm sockets
      13 mm open end wrench (I needed this to remove my skid plate)
      snap ring pliers
      gasket scraper
      compressed air
      Required Parts:
      New clutch cover gasket, Suzuki Part # 11482-29F00
      Tube or can of RTV sealant
      Oil filter and oil (if you plan to change the oil)
      1. Remove your skid plate (if you have one). I have a Tonn's skid plate and it was in the way.
      2. Remove right side radiator cover.
      3. Unbolt the rear brake lever. This will require removing a cotter pin on the backside of the bolt, and then the bolt itself. I was able to swing the lever far enough out of the way without completely removing it from the bike (see pic).
      4. Drain the coolant. This requires removing the radiator cap and the small bolt on the water pump, which has an aluminum washer on it. I rocked the bike from side to side to get most of the coolant out of the bike.
      5. The oil, two options here. You can either drain the oil and remove the oil filter or you can do what I did which is lay the bike on its left side to keep the oil from pouring out of the engine when you remove the clutch cover. I still removed the oil filter so I could clean the clutch cover with brake clean after scraping the old gasket off.
      6. Loosen the hose clamp on the coolant hose that attaches to the top of the water pump and fold the hose out of the way.
      7. Remove the water pump cover and the clutch cover by removing the bolts holding them on. Note that some of the bolts are of different sizes so keep track of which hole you pulled them from. Also, not all of the bolts need be removed, see the pic below.
      8. Remove the old gasket from the clutch cover and/or the engine with your gasket scraper. I then cleaned the clutch cover with brake cleaner as it was fairly oily.
      9. With your snap ring pliers, remove the snap ring from the plastic gear on the clutch cover seen here:
      10. Remove the plastic gear.
      11. Push out the metal pin and remove the washer underneath as seen here:
      12. With a screwdriver or whatever your preferred tool, remove the “E” clip as seen here:
      13. After removing the “E” clip push the water pump shaft out of the clutch cover.
      14. You will now have the part in your hand that needs fixing. Remove the porcelain gasket at the bottom of the shaft by blowing it with compressed air. Don’t not pry it with a screwdriver as it could damage the gasket. Mine was stuck fairly well so I sprayed some WD-40 on first to loosen it up.
      15. If you used WD-40 clean the shaft and gasket with some brake cleaner and then apply the RTV sealant to this area (I reused this pic as its perfect):
      16. Push the gasket back down flush on the shaft wiping away any excess RTV that may flow out.
      17. Reassemble the shaft into the clutch cover in reverse order as listed in steps 9-13.
      18. Place your new clutch cover gasket on the engine and then place the cover back onto the bike.
      19. Put the bolts back into the clutch and water pump cover and tighten equally. I could not find a torque setting for these in the manual so I snugged them evenly.
      20. Put the oil filter or a new one in the bike and put the oil filter cover back on.
      21. Re-attach the brake lever and tighten the bolt to 21 ft lbs. Be sure to install a new cotter pin on the backside of the bolt.
      22. If you drained your oil, refill the crankcase with the proper amount. If you didn’t drain the oil be sure you have enough in the crankcase from oil lost from removing the clutch cover.
      23. Let bike sit for 24 hours to let the RTV set up before adding coolant.
      24. Re-attach the coolant hose to the top of the water pump and tighten the hose clamp.
      25. Fill the radiator with a “Silicate Free” anti-freeze and put the radiator cap back on and tighten the radiator cap screw.
      26. Put the radiator cover and your skid plate back on the bike.
      27. You are done, go ride!
      This post has been promoted to a wiki
      Since I've been getting a few requests a week to e-mail the re-jet instructions word document (offered to send it to someone in old post that lives on) I thought I'd throw this post together. It is perhaps the one stop shop for 3x3 mod info: the master 3x3 post
      The 3x3 Mod
      So what is the 3x3 mod anyway? Well, this mod is basically re-jetting your carb and allowing it to run to its full potential. This mod can be done by even the most newbie of wrenchers out there. 3x3 refers to the size of hole that you will need to cut into the top of your airbox where your snorkel currently is. Don’t worry, you are not carelessly risking getting water into your engine by removing the snorkel. The bread and butter of the mod is the taper of new needle which you will get with your kit.
      Jet kits can be found through the TT here
      Scroll down to the bottom to find the right kit for your DRZ
      If you purchased a S kit for SM by accident don’t worry it will work (different jetting specs are used, just ask!)
      There are some great instructions outlining the procedure and here are two:
      bayoubikebruiser’s post is a nice one (Good Job BBB)
      Note that BBB followed the TPS sensor wire back and detached from the clip it there rather than removing the TPS off the carb.
      Another read is the attached word file (which i convereted to pdf and can be found here for your convenience) which has ‘been around the block’ to say the least.
      Sample Jetting recommendations (note: these are different for different elevations and different bikes)
      - 150 main jet (155mj for full exhaust system)
      - 25 pilot jet
      - 2nd clip on needle from top
      - 2.5 turns out on fuel screw
      - 140 – 142.mj (bigger for exhaust)
      - 25 pilot jet
      - 4th position from top
      - 2.5 to 3 turns out on fuel screw
      Burned’s fuel screw setting method:
      with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
      this should happen between 1 and 3 turns out.
      if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
      choose the appropriate size and retest.
      The 25 Pilot jet part number for TT is:
      So… now you have the info that you need, get to it! Your bike will sound better and rip a little faster; get ready to grin!
