is it possible?drz125 bike
Is it possible to fit the ufo black or yellow front fender on my drz125???T:ride: hanks Allan
most likely, if its universal, you should be able to drill holes and fit it in easy. if its bike specific, then check up in the dimensions, it might still work (but you might need to make new holes), you dont want to go to big because the rear end of the fender might hit the frame. hope this helps!
