ttr125 brass plug
Is the brass plug on the carb of a 06 ttr125 that needs to be drilled out to gain access to the fuel mixture screw on the right side of the bike (kick starter side) The only adj screw the manual shows is on the left and it's listed as the throttle stop screw. I started to drill what I thought was the plug on the right side of the bike, but stopped short as I thought it seemed very deep.
After switching the main and the pilot I assume it's on the bottom of the carb that runs next to the fuel bowl?
From what I remember, it is on the bottom side of the carb, in the center and on the engine side. It is in front of the fuel bowl.
From another thread:
See if this helps...
