Last weeks Desert Dash 2007 ride.
It was fun but grueling. We all rode about 180 miles of rocky, hilly and deep sandy desert on day one but the next day was supposed to be another 140 mile ride. Most didn't do it. I hurt my knee and couldn't.
Here's some pics on the San Diego Adventure Rider site:
The weather was fantastic and my friends put up with my complaining. Lack of sleep and major heartburn messed it up for me but it was worth the new experience of seeing the desert in the best conditions possible.
I had a blast! I'm ready to sign up for next year already. My biggest regret was that we didn't get enough pictures.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
