Anyone know if a FMF hi-flow header will mate to a Big Gun rear box?
I have a Big gun rear box and ordered a FMF high flow header simply because Big Gun was all out and wouldnt have any for quite a while. If I gotta get a FMF rear silencer then fine...
no one??
From what I can remember of the one I had before, the FMF header is the same dia. as the E pipe...
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
