Kickstart stripped, what all should I buy?
I have to replace 3, & 20. What else should I buy? Thanks for any help, I don't have a repair manuel.
11 (if it's the seal, pretty sure it is) and a clutch side cover gasket, and 1, 2, and 10 if needed. I'm pretty sure 14, 021, 21, and 22 are the ratchet mechanism, might take a look at those too. They're prone to wear, worse on bigger bore bikes.
3,20,and gasket are all that you really have to do. The others are if you need em. The bolts do snap off after a few years of use so it might be good to replace it. Use red loctite on it when you put the bolt on.
