will the rear rack from a klr650 fit a klr250?
hi:
will the rear rack from a KLR650 FIT A KLR250?
Not quite, I think; and . . . in my experience, the factory KLR250 rack's miserable, fit-wise.
Had to drill hardware for the turn signal stem locating pegs; otherwise, the stems don't penetrate the rack and existing mounting holes enough to thread the nuts. You could grind off the pegs, or shorten the turn signal stems overall, but--out of the box, the rack won't fit without alterations, no matter what the instructions say.
Then, after installation, the rack is rated for a whopping 5-pound load . . .
