DR200SE petcock , I have the solution!!
I took a risk, and ordered a DRZ400E petcock thinking it should work for my DR200SE to eliminate the vacumm problems they eventually get. The gasket numbers were the same, so the risk was pretty safe, well, the dimensions are perfect and it bolts right up to the stock fuel tank, however, you'll need to pull out your stock fuel tube(longer one that goes into tank) with a twisting motion, and install in the new petcock, or shorten the one on the DRZ petcock, as it is really high, looks like it will cut 50 miles off your main fuel range, but add it back at the reserve end, no real big deal. The fuel nipple also rotates so you can get it set up nicely. I will post some pics when I get it installed. I like this better than using the pingle setup with it's teflon tape and whatnot, and it looks more OEM.
