no power
here is the problem i am having now, bike starts and ilde fine but when try to snap the throttle, acts like no fuel.
trys to die and will if hold the throttle open.
any ideas?
It's starving for fuel. Did you do any mods, or anything to the bike before this started happening. Also is it just a bog and then it revs up if you give it gas slowly, or does it not rev up at all without trying to cut out. If it is just a bad bog when you snap the throtle then try doing the AP mod.
the only thing i did was wash the bike?
then this started
its not the normal bog on accel, i mean it will not accel at all past ilde speeds.
thanks again
Sounds like water might have gotten into your carb. When the float bowl is full of fuel the water sits on top of gas, when you give it gas the level of fuel decreases obviously and water's surface tension does not allow it to pass through the jets so yea I would definately check that out. Hope you get it fixed, later
