CR125 gas tank differences?
Does anyone know the differnces between the cr125 00-01 gas tanks and the 02-06 gas tanks. Why wouldnt they all be compatible, their both perimeter frames. Thanks
they are both perimeter frames, but they 2 different generations of frames, so the tanks are different...
Whats different about them. Is it the mounting points. I dont thing they would change the frame geo that much. I guess Ill have to be the kinney pig and see if I can get it to fit.
the newer tank will fit into the older frame, but its tight. the mounting points for the shrouds is whats different(further apart for the 02+ tanks). also the way the back of the tank sits on the frame itself is a little different...
and to run the new shrouds, you will need to make a mounting bracket for the lower rear shroud mount.
