klx crank questions.
Can the rod be replaced on a klx 300 crank or will it need a whole new crank shaft? It has a 330 kit, but upon inspection the rod is egg shapped were it connects to the piston so it needs to be replaced. does the crank press apart? The guys at the part store said its all one piece, which is wierd.
thanks
