07 klx250 jeting
does anybody know if the stock jetting is good at 200m if not wat do u recomend bike completly stock
G'day,
I ride in the Pilbara region of Western Australia at around 700m with an '03 KLX250R which should be similar spec to yours, pretty sure they haven't changed much for years.
I recommend doing all the free mods,ie: remove airbox cover, reroute carb vent tubes, most important is to block the 2 holes in the carb slide and then remove the bung in the exhaust or better yet toss the lot and go aftermarket.
I found that even at my height I still needed to raise the needle and go up 1 size on the main jet to get it to pull in the top end.
You will find though that the carb is probably the most inaccessible on the market and requires plenty of swearing :thumbsup: and disassembly :) to remove to do this work.
