06 yz250f fork fluid / off road suspension settings
I'm going to finally change the fork fluid on my 06 yz250f. Wanted to see what everyone recommends for mainly off road / trail / desert riding, also what suspension settings? Thanks
I am doing the same, but I ride MX only. Look at some of the posts over on the Suspension Forum, there is a ton of information over there, you just have to sift through it. What I have found is that the Front seems good for a 180 lb rider yet the back is a little to stiff unless you weigh 190. Now those are for MX, it should be softer for off road. What is your weight??
170 LBS without gear.
You are right on the bubble up front, but stock is probably a little to stiff , especially for off-road. I would say that the back is way over sprung for you.
i would try to PM John Curea @ MX-Tech, he is the moderator on the Suspension forum and his rep is very good.
