2006 YZ 250 Rebuild Parts List
Can anyone tell me or point me to some place that I can get a complete list of gaskets, seals, and what ever else I should be replacing on my motor while it's apart?
I cracked the center case at the drain plug and it has to be welded or replaced so while everything is apart what else should I be looking at with a motor with maybe 30-40 hours on it? The top end is still pretty fresh but I don't know what else to look at for excessive wear.
Is there some where you can order a rebuild "kit" that comes with all the necessary gaskets, seals, and bearings or whatever else is needed to put back together a perfectly running engine before it was taken apart to repair the case?
It sucks ripping into a perfectly running motor...unless you’re going to put a WR's 3rd, 4th and 5th gear into it or something great like that.
Thanks for any help
Your local dealer or maybe on this board in the TT store can supply all of that in aftermarketparts.Seal kit and or gasket kit and crank bearings
i think Valdosa(spelling) offer's a gasket and seal kit together.
