KLX 110 BBR tapered steering head kit
Anyone else try to install this kit? I'm having no luck figuring out the seals. I've tried every way I can think of. But unable to find a combination where the selas will actually seal the bearings from dirt, water etc. Kit comes with absolutely zero instructions.
Can You Post Pics Of The Parts?
Thanks for the reply. I dont have any pictures. But contacted BBR, it appears the thick shim goes on the bottom of the stem, (inside radiused edge goes downward) then the seal (lip up) then the lower bearing and then on top, upper bearing, seal (lip downward) and then the dust cover, spanner nut then the top triple clamp. I have it all together, but the upper race just wont go in any further for the seal to work. I was told the race isnt in enough. But I looked, its bottomed out in the seat. Oh well, will run it, was told the race would go down after some riding if it wasnt in all the way. I checked the website "BBR Motorsports" and it only showed the bearings themselves.
