Mounting Rally Logger on KTM 525
Has anyone had to mount the Rally Logger bracket on a newer model KTM? The newer model KTM's (2006+) do not have a flat rear fender. There is a peak in the center of the fender that makes mounting the bracket a bit of a challenge. If anyone has successfully mounted the bracket on a newer model KTM and wants to share their suggestions, it would be greatly appreciated.
Justin
18x
Not sure what a "Rally Logger" is, but I would put spacers (could use washers/sleeves for hard mount or rubber grommets for soft mount) under the mounts to increase the clearance hight in the area of the fender crease.
Bruce
