what do you think of this?
OK this is going to be an IMOP.
Ima say bad over the long hall. I haven’t bean working on bikes for long BUT I have bean-building award winning Toyota supras for years. Hear is the long and short of it. PCV system pulls all the built up presser from the crankcase of a car. All that oil vapor gets pulled back into the motor to be burnt in the cylinder. The + for this is lower crankcase presser. The con of this is buildup on the back of the valves. The oil that gets sucked into the cylinder terns into a black goooo on the back of the valve then gets baked on. Same thing happens if you over oil your air filter. So over time the valve becomes les efficient.
How does that sound?
