Should I try to fix it myself or leave it to a pro?
Hi all,
I'm having a few problems with my recently purchased 2001 DRZ400E. See details of what my issues are in my other thread:
http://www.thumpertalk.com/forum/showthread.php?t=477629
In a nutshell, any one of the following could be causing my woes:
- Valves
- Carby (pilot Jet dirty)
- Accelerator Pump
- Bad Fuel
So my bike needs a bit of work to get her running well and I'm trying to decide if I should give it a go myself (with manual in hand) or just pony up the dollars and pay someone that does it for a living.
I have a road bike backgound (all fuel injected) and possess what I'd call a "limited to average" ability working on my road bikes. I do the basic stuff like replacing a drive chain, sprokets, brake pads, bleeding the brakes, oil/filter changes, coolant changes etc. I have no experience working on the real guts of bikes. I also have ZERO experience with carbs/jetting.
Given my limited background, how realistic is it be for me to do the following to try and get my bike working in a reasonable time frame? (I don't really want it to take me 3 weeks of stuffing around)
1. Valve check (maybe adjustment if required)
2. Carby clean/overhaul/adjustment
3. Choke assemble replacement
4. Accelerator Pump check
5. Spark plug replace (while I'm in there may as well do it)
For a rough comparison, approximately how much time would your average competent mechanic take to do the same tasks.
Cheers
Greg
i would ''weigh up '' the advantages and disadvantages of
1 fixing it yourself
2 shelling out the $$$ .
do you have the mechanical aptitude and the tools required to do the job ??
do you have the $$$ to spare ??
...do you have the mechanical aptitude...
I have no idea :applause: I don't know how hard or involved the tasks are.
Do I have the spare $$? Well technically yes, but there's always something I'd rather spend the money on, like off road gear.
I think I'd have most, if not all the tools I need.
I should also mention that I don't have my Clymer service manual to refer to yet. It'll be turning up in the post in a week or so. Obviously if I had it, I'd have a much better idea if I was capable of performing these tasks.
Cheers
Greg
