07 RMZ 450 clicker settings
Having a few issues with my 07 RMZ450.
I have set the sag at 100mm, I weigh 80kg(160????) stock clicker settings are bit soft for full moto but, as I stiffen the the compression it starts to push slightly in the front and wont settle into the flat turns as well & the rear has started to kick a little bit too much.
Presently running 4clicks out on the fork compression, and rear high speed 8 out from hardest and low speed half a turn harder from stock, (1.5 truns out from full hard I think).
Re valve on the cards, no break in racing for few more weeks
80kg is 176lb, you have the rear clickers description wrong, you are 8 out on compression low speed and half a turn out on the high speed, it sounds like you need a revalve if your clickers are 4 out on the forks, you could try 10wt oil in the outer chambers for better bottoming control(set at same oil amount as std) i would think the springs are very close for your weight.
