Exhaust Collars
what is the best exhaust collars are the metal ones any better than the oem rubber ones I have a 94 cr250
They both suck!! My Hondas have always leaked like the exxon valdez at the pipe junction. You need to use rtv sealant to fix the leak every time you remove the pipe.
Forget stock,I used to rip them upon installation..lol.
I used a rubber Radiator hose that was just the right size and put hose clamps on both ends.
I did that about a year ago and no leaks yet and it looks like it was meant to be there.
Just measure your pipe and silencer ends and get some Hi-temp hose or radiator hose that is just a lil bit bigger than your pipe dimensions and get two hose clamps and your all set.
Good Luck!!
stock on my 02 cr250 works well. put two cable ties on there, one on the silencer side and one on the pipe side and almost all the leakage will stop. of course jetting your bike correctly so it doesnt smoke much also will help
