06 CRF150f fuel screw
What's up with the piece o crap fuel screw on the 06 CRF150? Any suggestions for removing and replacing it?
Thanks
Thanks guys...good info. Does that bit fit in the hole?
this one:
BIT, D-SHAPE F/USE WITH 08-0229
and u dont need the wrench they sell in case your wondering..
Yes it does , the bit is very small you'll be surprised. just buy the bit for $2.90 because when you pull your carb off you'll have easy axcess to it , put the bit in a removeable tip screw driver it fits perfect. then if you want buy one of these http://www.crfsonly.com/catalog/product_info.php/cPath/27_61/products_id/1362?osCsid=41828c2900a9024ad42cad7c4be772b8perfect. this way you can adjust setting with the carb in place .
micro2992 make sure it is the D shape I don't know foresure 06 150 is or not, I have 07 230 & that's what it is, but heybuddy's pretty noligable on all these bikes so it probly is.
Don't want you to buy something you don't need.
